It is becoming bigger and bigger, and there is more information that
we would like to put online.
We were wondering whether we could create other pages on the OSGeo wiki?
If yes, should they have a common prefix? Or follow some naming conventions?
Or, alternatively, should we rather use the wiki capabilities of our
Trac instance to build this knowledge base?
Thanks in advance for your recommendations!
Mathieu
You are welcome to create pages as you see necessary, the wiki is a
community resource to be used. That said it's up to you if you'd like to
use the main wiki or your Trac wiki. The advantage to the main wiki is
probably more traffic and the easy linking to other wiki pages. Of
course you could always just link your current page to the trac site wiki.
For creating additional pages you have several options.
1: a prefix as you mentioned (not sure what a good one is EL seems to
easy to mix up with a language)
2: a category
3: name pages as appropriate
I think a mix of 1 & 2 will work well for your collection of pages.
There is however not set standard that I've seen.
