I'm trying to produce a dump of the openlayers_blog mysql database
on osgeo6 but the username/password found in the systemwide configuration
doesn't seem to work. Did anyone change some credentials there or knows
how to win a battle against mysql ? (I try to stay away from it...)
Using the "root" user it worked, at least it exported something. See
in the ticket.
Yep, looks like working, but... where did you find the password ?
It would be good to document the configuration somewhere, a great
starting point could be https://wiki.osgeo.org/wiki/Osgeo6
I've stubbed a "mysql" section there, if you have any useful info.
BTW: should the table in ProjectsVM also be updated adding
"moved to osgeo6" labels in the "comments" column ?
According to the [Osgeo6 section](https://wiki.osgeo.org/wiki/SAC_Service_Status#osgeo6)
in ServiceStatus page, only "grass.osgeo.org", "grasswiki.osgeo.org"
and "dev.openlayrs.org" were moved. Is that information useful at all ?
Or we could turn that section into a simple link to the dedicated OSgeo page.
Well, I/we used it in the past years because the GRASS GIS Wiki is
also managed on that server in mysql.
I didn't really configured it, probably Martin S did so (or Martin L).
But that's up & running since osgeo6 exists.
Not qute, it is rather confusing at time.
+1
SAC_Service_Status#osgeo6 turned to a simple link to dedicated Osgeo6 page,
where I've added the missing available services. I guess in the long run
it would be good for each service to have its own page, and have it linked
from the page dedicated to the machine (virtual or real) hosting it.
There's still a lot of confusing/old info in that page, any volunteer to
clean things up more ?
