We'd like to create a new 100G LVM volume and mount it to the QGIS VM on
osgeo4. A reboot is fine if needed, afternoon PST times are good for
that. We can format it once it's mounted (plan is for XFS).
I believe in order to make this happen the retired Backup VM needs to be
deleted from Ganeti.
On 05/23/2014 10:00 AM, OSL Systems Support Team via RT wrote:
Greetings,
This message has been automatically generated in response to the
creation of a support ticket call:
"New LVM volume on osgeo4 QGIS VM",
a summary of which appears below.
There is no need to reply to this message right now. Your ticket has been
assigned an ID of [support.osuosl.org #23900]. Please include this string
in the subject line of all future correspondence about this issue. You may
also catch us on irc (irc.freenode.net) in #osuosl.
This ticket is mildly urgent, the QGIS VM really needs more space for
their upcoming release.
Alex
PS: At some point we should discuss how to allocate more of these menial
tasks to OSGeo directly.
On 05/28/2014 09:43 AM, tech@wildintellect.com via RT wrote:
Ping - has this ticket been assigned to anyone?
Alex
Greetings,
I want to confirm with you that it is ok to remove the backup osgeo vm from ganeti. Note that data contained within that vm will not be able to be recovered once it is removed. Adding the disk should be fairly quick and we can let you reboot the vm at your own discretion if you desire.
Thank you,
On Mon Jun 02 13:05:44 2014, tech@wildintellect.com wrote:
OSUOSL Team,
Alex
menial
> Thanks,
> Alex
>> Greetings,
has been
string
You may
>> Thank you.
>> support@osuosl.org
>> OSUOSL team,
VM on
for
to be
>> Thanks,
>> Alex
>> OSGeo Sys Admin Committee
> Sac mailing list
> Sac@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
Anthony Miller
Student Systems Engineer
Oregon State University | Open Source Lab
After looking into it I realized that the qgis vm is on osgeo4 which has enough free disk space. I added the disk and need to reboot the machine within ganeti. When would be the best time?
On Mon Jun 02 16:14:05 2014, armiller wrote:
Alex,
Thank you,
> OSUOSL Team,
for
> Thanks,
> Alex
> menial
> > Thanks,
> > Alex
> >> Greetings,
> has been
this
> string
issue.
> You may
> >> Thank you.
> >> support@osuosl.org
> >> OSUOSL team,
QGIS
> VM on
> for
needs
> to be
> >> Thanks,
> >> Alex
> > _______________________________________________
> > Sac mailing list
> > Sac@lists.osgeo.org
Anthony Miller
Yes, I can confirm. We no longer use that VM now that we have a
dedicated machine in the rack.
PS: I'm on the IRC channel if there are additional questions.
Alex
aka wildintellect
Alex,
Thank you,
OSUOSL Team,
for
Alex
menial
Alex
Greetings,
has been
this
string
issue.
You may
Alex
aka wildintellect
Alex,
Thank you,
OSUOSL Team,
for
Alex
menial
Alex
Greetings,
has been
this
string
issue.
You may
