Jeffrey,
We’ll check out the error log issue.
I confirmed I can see all the admin pieces now when I log in.
I’ve cc’d SAC so they are all aware of status of staging.www.osgeo.org server
Regina
From: Jeffrey Lasut [mailto:j.lasut@getinteractive.nl]
Sent: Monday, November 20, 2017 3:53 AM
To: Regina Obe lr@pcorp.us
Cc: Sandro Santilli strk@kbt.io; Alex Mandel tech@wildintellect.com; Jody Garnett jody.garnett@gmail.com; Martin.Spott@mgras.net
Subject: Re: [OSGeo] #2010: New Website allow LDAP integration
Hi Regina,
The last config changes needed for the SSL are done. I also made your account administrator.
I disabled the custom error and access logs in /etc/apache2/sites-available/www.osgeo.org-common.conf, somehow this isn’t working anymore.
If this is enabled I’m unable to restart the apache without errors (apache error log):
[Mon Nov 20 09:23:30.726905 2017] [mpm_prefork:notice] [pid 20226] AH00169: caught SIGTERM, shutting down
error: cannot stat /var/www/osgeo.org/logs/error.log.%Y-%m-%d-%H_%M_%S: No such file or directory
error: cannot stat /var/www/osgeo.org/logs/access.log.%Y-%m-%d-%H_%M_%S: No such file or directory
We usually do our WordPress and plugin updates not in a production environment but in a separate staging environment, that’s why it’s disabled by default.
You can enable updates in /var/www/osgeo.org/httpdocs/config.php by setting $pluginAndThemeEditor and $pluginAndThemeUpdateAndInstallation to true.
Best regards,
Jeffrey Lasut
+31 (0)30 60 808 48
www.getinteractive.nl (Nederlands)
www.getinteractive.org (English)
Dorpsstraat 50, 3433 CM Nieuwegein
Op dit e-mailbericht zijn de algemene voorwaarden van Get Interactive van toepassing.
Deze kunt u terug vinden op onze website http://www.getinteractive.nl/algemene-voorwaarden/.
On 18 November 2017 at 09:09, Regina Obe <lr@pcorp.us> wrote:
Jeff,
I have SSL in place now with let’s encrypt
I had to muck with the /etc/apache2 files to allow ./well-known to be accessed so that letsencrypt could approve the cert
and to follow strk’s example from other server he set up, the new ssl site I setup and the old, I move all the common conf settings into www.osgeo.org-common.conf
Also can you make my wordpress account have admin access to be able to change things like the default url and upgrade plugins and Worpress install.
Regina
Sent: Monday, November 13, 2017 5:32 AM
To: Regina Obe <lr@pcorp.us>
Cc: Sandro Santilli <strk@kbt.io>; Alex Mandel <tech@wildintellect.com>; Jody Garnett <jody.garnett@gmail.com>; Martin.Spott@mgras.netSubject: Re: [OSGeo] #2010: New Website allow LDAP integration
Hi guys,
Please let me know when SSL is installed. I’ll have to do some config work on the site to make this work.
Best regards,
Jeffrey Lasut
+31 (0)30 60 808 48
j.lasut@getinteractive.nlwww.getinteractive.nl (Nederlands)
Deze kunt u terug vinden op onze website http://www.getinteractive.nl/algemene-voorwaarden/.On 13 November 2017 at 11:23, Regina Obe <lr@pcorp.us> wrote:
Yah works for me too.
I think Martin was going to install Letsencrypt on server. I’ve cc’d him.Thanks,
Regina-----Original Message-----
Sent: Monday, November 13, 2017 5:17 AM
To: Jeffrey Lasut <j.lasut@getinteractive.nl>
Cc: Regina Obe <lr@pcorp.us>; Alex Mandel <tech@wildintellect.com>; Jody
Subject: Re: [OSGeo] #2010: New Website allow LDAP integrationOn Mon, Nov 13, 2017 at 10:17:15AM +0100, Jeffrey Lasut wrote:
Site is now running on http://staging.www.osgeo.org/.
Great, thank you. Next we want https working (with letsencrypt), and any
http redirected to https.–strk;
