Notice, we are starting to get warnings about space on Adhoc being about
92% full. If you have older materials that are no longer needed on there
it would be appreciated if you could remove them.
I will attempt to analysis the directories later to figure out where the
biggest users might be.
On Mon, Jan 28, 2013 at 7:34 PM, Alex Mandel <tech_dev@wildintellect.com> wrote:
I'll take a crack at cleaning this up, and perhaps putting a cronjob
to keep this fairly clean.
Jeff - let me know if you have any thoughts.
Best regards,
Frank
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
OK, I've cleaned out the ms_tmp directory, and I've got a crontab
running on my account to clean files older than one day from that
directory. I'll need to check back some time to make sure it is
working properly.
We now have 22G available on Adhoc.
Best regards,
Frank
On Tue, Mar 26, 2013 at 5:17 PM, Frank Warmerdam <warmerdam@pobox.com> wrote:
Markus / Jeff,
Best regards,
Frank
This VM is heavily used (all MapServer demos use it). Thanks for
cleaning the MapServer temp images Frank.
-jeff
On 2013-03-26 9:17 PM, Frank Warmerdam wrote:
Markus / Jeff,
Best regards,
Frank
