#101: Wiki table formatting does not work in Trac
Reporter: mloskot | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Component: SAC
Keywords: formatting trac wiki |
According to the Trac docs, it should be possible to format non-simple
tables
with [wiki:WikiFormatting reStructuredText] or using
[http://moinmoin.wikiwikiweb.de/HelpOnTables MoinMoin markup for tables].
I tried to use all of these options and none works for me.
I can only format simple tables with double pipes:
||a1||a2||
||b1||b2||
what looks as follows:
||a1||a2||
||b1||b2||
May be there are some configuration options required to enable support of
more Wiki formtters or reStructuredText.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/101>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords: formatting trac wiki
Comment (by mloskot):
Hobu has turned on reST support successfully. It works so the ticket can
be closed.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/101#comment:1>
Type: defect | Status: closed
Resolution: fixed | Keywords: formatting trac wiki
Changes (by hobu):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/101#comment:2>
