#1027: Change PostGIS trac notification target to postgis-tickets
Reporter: pramsey | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Right now PostGIS trac sends change info to postgis-devel@lists.osgeo.org,
there is now a new list postgis-tickets@lists.osgeo.org which should
receive those mails.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1027>
OSGeo <http://www.osgeo.org/>
Comment(by pramsey):
Just edit the
/osgeo/trac/postgis/conf/trac.ini
file and change postgis-devel@lists.refractions.net to postgis-
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1027#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: trac |
Changes (by warmerdam):
* keywords: => trac
* status: new => closed
* resolution: => fixed
Comment:
Paul,
I have made the change, and restarted apache which I hope will put the
change into place.
Let me know if the change doesn't seem to have worked.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1027#comment:2>
