#1086: Access to mailman VM
Reporter: jmckenna | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
I'd like to have access to login to the mailman VM to occasionally
generate/check usage stats. My username is jmckenna
-jeff
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1086>
OSGeo <http://www.osgeo.org/>
You should be able to SSH in using your OSGeo user id and password.
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Comment(by jmckenna):
The error message I receive with my osgeoid is:
You must be a uniquemember of cn=sac,ou=Shell,dc=osgeo,dc=org to login
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1086#comment:1>
Hi Martin,
-jeff
Martin.
Ah, I see, I was assuming the telascience group would be sufficient,
thus someone should add you to the "sac" group. There are a few uid's
in the list I've never heard before, thus adding one more for the
President doesn't make a big difference ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
I currently don't have web access to the respective frontend, therefore
"someone" won't be myself for the next four hours, I'm sure "someone"
else can take over.
Martin.
This would still be helpful for me.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1086#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
Jeff,
I have added you to the "sac" shell group.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1086#comment:3>
Keywords: |
thanks Frank
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1086#comment:4>
