#1116: ssh access for bartvde to www.openlayers.org
Reporter: bartvde | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords:
Can I please get access to www.openlayers.org to do a release (2.13).
I need have ssh access and be able to change to the user openlayers on
there in order to do the release.
TIA
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1116>
OSGeo <http://www.osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: ldap |
Changes (by warmerdam):
* keywords: => ldap
* status: new => closed
* resolution: => fixed
Comment:
Bart, I have added you to the "shell" LDAP group that should give you
access to the projects server where www.openlayers.org is hosted, and the
download server. You may need to be added to an openlayers related group
on the server to have write permissions in particular directories. Just
let me know if that is so.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1116#comment:1>
Type: task | Status: reopened
Keywords: ldap |
Changes (by bartvde):
* status: closed => reopened
* resolution: fixed =>
Comment:
Hey Frank, thanks for the quick action, I think I need to be in the
sudoers list in order to change into openlayers (I verified this
assumption with Eric Lemoine). TIA.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1116#comment:2>
Keywords: ldap |
Comment(by warmerdam):
Bart,
On the ProjectsVM I've added you to the openlayers group now, which (I
think) should let you su to the openlayers user. For instance, to get a
shell logged in as openlayers do:
sudo -u openlayers bash
If you still run into problems let me know and I'll just give you general
sudo access.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1116#comment:3>
Keywords: ldap |
* status: reopened => closed
Comment:
thanks Frank this seems to work fine now
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1116#comment:4>
