#1248: Can't log into Maestro 4.0.0
Reporter: educker | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: Meastro 559 MgConnectionFailedException
Hi Guys,
I've installed Maestro onto Win7 64bit along with mapguide 2.4. It's
running on apache 2.2.21 and I can't log on to the port it's set up for. I
get this error in windows
Failed to log on because: Failed to connect, please check network
connection and login information.
Extended error info:
The remote server returned an error: (559)
MgConnectionFailedException.
Checking the error.log for apache I'm seeing this set of messages after
restarting apache then trying to log into maestro
[Fri Oct 18 15:01:51 2013] [notice] Child 2564: Exit event signaled. Child
process is ending.
[Fri Oct 18 15:01:51 2013] [notice] Apache/2.2.21 (Win64) configured --
resuming normal operations
[Fri Oct 18 15:01:51 2013] [notice] Server built: Feb 2 2012 02:03:24
[Fri Oct 18 15:01:51 2013] [notice] Parent: Created child process 5068
[Fri Oct 18 15:01:51 2013] [notice] Disabled use of AcceptEx() WinSock2
API
[Fri Oct 18 15:01:51 2013] [notice] Child 5068: Child process is running
[Fri Oct 18 15:01:52 2013] [notice] Child 5068: Acquired the start mutex.
[Fri Oct 18 15:01:52 2013] [notice] Child 5068: Starting 50 worker
threads.
[Fri Oct 18 15:01:52 2013] [notice] Child 2564: Released the start mutex
[Fri Oct 18 15:01:52 2013] [notice] Child 2564: All worker threads have
exited.
[Fri Oct 18 15:01:52 2013] [notice] Child 2564: Child process is exiting
[Fri Oct 18 15:01:53 2013] [notice] Child 5068: Listening on port 8250.
( 7 6 6 4 ) D e f a u l t D i r : " C : \ P r o g r a m D a t a \ A u
t o d e s k \ G e o s p a t i a l C o o r d i n a t e S y s t e m s "
i s n o t a d i r e c t o r y ! I n s t a l l t h e C o o r d
i n a t e S y s t e m l i b r a r y i n t o t h i s d i r e c t
o r y o r s e t M E N T O R _ D I C T I O N A R Y _ P A T H t o
w h e r e t h e y a r e c u r r e n t l y i n s t a l l e d .
( 7 6 6 4 ) M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i
o n F a i l e d E x c e p t i o n c a u g h t i n C C o o r d i n a
t e S y s t e m C a t a l o g c o n s t r u c t o r - T h e c o o
r d i n a t e s y s t e m i n i t i a l i z a t i o n f a i l e d .
- M g C o o r d i n a t e S y s t e m C a t a l o g . S e t D e f a u l
t D i c t i o n a r y D i r A n d F i l e N a m e s ( ) l i n e 6 0 4
f i l e . . \ C o o r d i n a t e S y s t e m \ C o o r d S y s C a t a
l o g . c p p
- M g C o o r d i n a t e S y s t e m C a t a l o g . G e t D e f a u l
t D i c t i o n a r y D i r ( ) l i n e 2 6 3 f i l e . . \ C o o
r d i n a t e S y s t e m \ C o o r d S y s C a t a l o g . c p p
[Fri Oct 18 15:07:00 2013] [error] [client 127.0.0.1] File does not
exist: C:/Program Files
(x86)/OSGeo/MapGuide/Web/Apache2/htdocs/favicon.ico
Any ideas why it's not working correctly?
Edward
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1248>
OSGeo <http://www.osgeo.org/>
