#1262: unable to sudo on webextra
Reporter: warmerdam | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
I have recently encountered this error:
warmerdam@webextra:/etc$ sudo ls
[sudo] password for warmerdam:
sudo: PERM_ROOT: setresuid(0, -1, -1): Operation not permitted
sudo: unable to open /var/lib/sudo/warmerdam/0: Operation not permitted
sudo: unable to set supplementary group IDs: Operation not permitted
sudo: unable to execute /bin/ls: Operation not permitted
I don't recall running into this before on an OSU OSL OSGeo VMs. I am in
the groups file for sudoing. I am guessing this is somehow related to the
recent upgrade/hardening.
A web search turned up the following that might be helpful:
http://osdir.com/ml/general/2012-03/msg19852.html
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1262>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
Frank is this still an issue ?
As I'm going to request sudo on that machine too...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1262#comment:1>
Keywords: |
Comment (by martin):
In the meantime almost all machines (only "secure" wasn't, as far as I
remember) have been converted to ldapd/nslcd, therefore this particular
issue should be resolved.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1262#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Sudo works for me. Assuming resolved. Frank please reopen if you still
have troubles.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1262#comment:3>
