#1269: Change dns entry for planet.postgis.net
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Can you switch dns entry for planet.postgis.net to just be a CName to
postgis.net
I've already setup planet.postgis.net on that server so should just work.
This is related to postgis ticket:
http://trac.osgeo.org/postgis/ticket/2568
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1269>
OSGeo <http://www.osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
Change made:
planet » postgis.net.
Note that winnie.postgis.net is still a cname to v.paragoncorporation.com
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1269#comment:1>
Keywords: dns |
* keywords: => dns
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1269#comment:2>
Keywords: dns |
Comment(by robe):
Frank,
Yah that's fine. We are rebuilding winnie so will probably be down for a
bit. Might move it to an interim server, but I'll let you know what the ip
of that is if that is the case.
thanks,
Regina
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1269#comment:3>
