#128: Trac does not validate ids in CC and assign-to fields
Reporter: dmorissette | Owner: warmerdam
Type: task | Status: new
Priority: normal | Milestone:
Component: Trac | Resolution:
Keywords: trac |
Comment (by cvvergara):
Conclusion on validation of ''reassign to''
'''When a valid ldap name is used:'''
- The change takes place and the mails are sent.
'''When a invalid ldap name is used:'''
- a warning is generated
- Warning: The change has been saved, but an error occurred while
sending notifications: 'list' object has no attribute 'update'
- The mails are not sent.
'''When fixing to a vaild ldap name'''
- On the next change (for example a comment) the mails are sent
Ticket URL: <#128 (Trac does not validate ids in CC and assign-to fields) – OSGeo;
OSGeo <Gter - OSGeo;
