#1351: foss4g alias changes
Reporter: dfuhriman | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Could you change our foss4g aliass?
We want to point foss4g2014-info to support@foss4g.zendesk.com
and on the various aliases could you replace bstweart@vtmgroup.com with
tnewell@vtmgroup.com?
Thanks, folks!
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1351>
OSGeo <http://www.osgeo.org/>
Comment(by EliL):
If you plan to grep, I think that Darrell means "bstewart"
See also, http://trac.osgeo.org/osgeo/ticket/1267#comment:14
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1351#comment:1>
Comment(by EliL):
Looking at that link now, can you also change kbott to bottk? (I really
messed that one up: changing Darrell's correct request into an incorrect
one. Sorry)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1351#comment:2>
Comment(by EliL):
Replying to [comment:2 EliL]:
one. Sorry)
Actually ignore the part about kbott/bottk, it is fine as is (kbott/bottk
has an alias).
The original request is still the same. Sorry about the noise.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1351#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
foss4g2014-info now points to the zendesk address.
The two bstewart addresses were changed to tnewell.
newaliases has been run so they should all be in effect now.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1351#comment:4>
