#1478: Relocate CodeHaus Jira
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: critical | Milestone:
Component: Systems Admin | Keywords: geotools, geoserver
Okay, adding an issue here to open a conversation with SAC.
CodeHaus (http://www.codehaus.org) is shutting down in one months time on
April 2nd:
* CodeHaus runs the JIRA issue tracker for GeoServer and GeoTools
projects)
* CodeHaus runs the Confluence wiki for GeoTools
We need to make plans to migrate ![:frowning: :frowning:](/images/emoji/twitter/frowning.png?v=12)
A license to use Jira for open source projects is available, this should
allow OSGeo to host an instance if SAC has capacity (in hardware and
volunteers) to assist.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1478>
OSGeo <http://www.osgeo.org/>
Comment(by wildintellect):
This isn't a simple yes/no question. I think we're going to need to have a
longer discussion on the SAC mailing list about options.
1. Yes we are working to rack new hardware this month, to fix and expand
current capacity issues.
2. Unless Geoserver or GeoTools et al. can volunteer an admin to run
Confluence, JIRA etc no we don't really have someone for that.
3. Alternate's include, OSGeo hosted trac, OSGeo hosted Gitlab (In
planning stages), Github, etc... any existing services we already use...
More details and place to write down needs:
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2014
Thanks - Alex
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1478#comment:1>
Comment(by jive):
Started discussion on SAC mailing list ...
1. Good news about hardware, we would need to see about how much capacity
Jira would require.
2. GeoServer/GeoTools PSC may be in position to act as admin as we would
prefer a vendor neutral home for the issue tracker.
3. We are also looking at Jira cloud hosting, but OSGeo is our preference.
The community has a strong push back to use of github / track / bugzilla
due to concerns about file size (for patches and test-data).
Not sure where on that wiki to put down needs. We are pretty stressed
about this sudden deadline, and the earlier we transition the better as I
assume codehaus will be hammered by projects migrating close to the
deadline.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1478#comment:2>
Make a bullet under
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2014#Current_Needs
Sub bullets with the relevant specs, disk size, etc...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1478#comment:3>
Comment(by jive):
Reached out to GeoAPI project who would also appreciate finding a home at
an OSGeo Jira.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1478#comment:4>
