#1537: 2014.foss4g.org SSL certificate expired
Reporter: neteler | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: ssl
As per subject line - it is a DigiCert SSL certificate, probably it needs
to be replaced with the OSGeo wildcard certificate?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1537>
OSGeo <http://www.osgeo.org/>
#1537: Configure ssl for FOSS4G archives
Component: Systems Admin | Resolution:
Keywords: ssl |
Changes (by EliL):
* type: defect => enhancement
Comment:
Now that DNS has been updated (#1525), this is a different problem. Now
it is that it is for the incorrect domain:
2014.foss4g.org uses an invalid security certificate. The certificate is
only valid for the following names: *.osgeo.org, osgeo.org
which is also the same for other years.
I've changed this to an enhancement to "Configure ssl for FOSS4G
archives". Closing this would be fine too.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1537#comment:1>
Keywords: ssl |
Comment (by wildintellect):
We should configure Let's encrypt for this. I believe the archives are
hosted on WebExtra.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1537#comment:2>
