#1551: Trac Spam
Reporter: pramsey | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: spam
PostGIS tracker is seing a growing amount of trac spam, in the form of
spurious attachments with links in teh comments
https://trac.osgeo.org/postgis/ticket/186
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1551>
OSGeo <http://www.osgeo.org/>
#1551: Trac Spam
Component: Systems Admin | Resolution:
Keywords: spam |
Comment (by jmckenna):
I've enabled the "!SpamFilter" plugin for other trac instances
(http://trac.edgewall.org/wiki/SpamFilter), is this plugin installed here?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1551#comment:1>
#1551: Trac Spam
Keywords: spam |
Comment (by strk):
Jeff do you have an example of a trac instance on OSGeo with the
SpamFilter plugin enabled ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1551#comment:2>
#1551: Trac Spam
Keywords: spam |
Comment (by strk):
I don't see SpamFilter listed here:
https://wiki.osgeo.org/wiki/Trac_Instances#Plugins nor I can find it
installed on the machine. Were you suggesting to install it for OSGeo
instances to use ? I'd still like to see it in action.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1551#comment:3>
#1551: Trac Spam
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: spam |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
SpamFilter is now installed and the postgis trac spam was all cleaned
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1551#comment:4>
