#1557: SVN hook errors get lost
Reporter: strk | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
I've found errors in the PostGIS SVN post-commit hook and found out they
get lost which explain why they survived for so long.
One of the errors is a mail to an inexistent address.
The mail is sent as svn_postgis@osgeo.org, but that address does not
exist, so the reply from MAILER_DAEMON never get to be read by anyone.
The other error is asyncronous, coming from a backgrounded wget process
spowned by the script. The wget'ed url is non-existent but the hostname
resolves and the firewall does not respond so that the client hangs
indefintetly (till timeout).it takes a long time to timeout. I still don't
know what will be output on timeout, but whatever it is, it doesn't hit
anyone.
I think the sane thing to do here would be to ensure SVN errors for a
projects are sent to a responsible person from the project.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1557>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
I found that "svn_postgis@osgeo.org" address is really specified in the
commit hook script itself, so not something generally inherited. I've seen
that trac mail (for "-tickets" mailing lists) are sent with from set to
"trac@osgeo.org". Does _that_ mailbox end up anywhere ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1557#comment:1>
Keywords: |
Comment (by neteler):
FWIW: You may want to look at
/var/www/svn/repos/grass/hooks/post-commit
for a working solution. It posts to
https://lists.osgeo.org/pipermail/grass-commit/
In the mailman setting of grass-commit we have specified the grass-dev
list as reply-to (in order to avoid that comments pollute the grass-commit
list and in order to reach the developers right away).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1557#comment:2>
Keywords: |
Comment (by strk):
Thanks Markus, that script is not much different from the one we had in
PostGIS, so it suffers of the same problem, that is shall the target email
(grass-commit@lists.osgeo.org) have a delivery error, that error will be
sent to svn_grass@osgeo.org which is an unexistent address.
This ticket is to define a policy about who should receive errors on such
occurrences (if anyone).
BTW, good idea about using -dev for reply-to!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1557#comment:3>
