#162: OSGeo Domain Redirects
Reporter: warmerdam | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: |
I propose that osgeo.net, www.osgeo.net, osgeo.com and www.osgeo.com be
redirected to osgeo.net.
Care should be taken to preserve test.osgeo.net pointing to the osgeo2
server.
It has been suggested that redirects rather than just direct dns pointing
with virtual hosts be used to preserve the authority of the osgeo.org
domain with search engines, etc.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/162>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords:
Comment (by jbirch):
You mean redirect to www.osgeo.com right?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/162#comment:1>
Keywords: |
.org ?
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Old description:
server.
New description:
redirected to osgeo.org.
server.
Comment (by warmerdam):
I mean to redirect to osgeo.org. Request text updated accordingly.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/162#comment:2>
Please, please also set up a redirect from test.osgeo.org to
test.osgeo.net, or at least park test.osgeo.org so that we don't have
accidental updates of the live site.
Wildcard DNS _sucks_
Jason
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/162#comment:3>
Comment (by sbarnes):
Jason, i set up a redirect from test.osgeo.org to test.osgeo.net.[[BR]]
As for the other, redirecting osgeo.net, www.osgeo.net, osgeo.com and
www.osgeo.com to osgeo.org...i'm not sure the best way to do this. Where
would we redirect from?
shawn
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/162#comment:4>
Maybe set up a virtual host for these, and then add a simple Apache
redirect inside of that virtual host to www.osgeo.org?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/162#comment:5>
Reporter: warmerdam | Owner: sac@…
Priority: normal | Milestone:
Component: Systems Admin | Resolution:
Keywords: |
Comment (by TemptorSent):
Connection to osgeo.net times out, connection to osgeo.com comes up with a
parking page for pair domains. If these domains are still valid, their DNS
records need to be updated to point them to a live server, then a http
redirect can be added if desired instead of hard-wiring them to the
address for osgeo.org.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/162#comment:6>
Component: DNS | Resolution:
Keywords: |
Changes (by TemptorSent):
* component: Systems Admin => DNS
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/162#comment:7>
Keywords: |
Comment (by Jeff McKenna):
I've set forwarding of osgeo.com to osgeo.org in the domain settings.
For osgeo.net it seems like at one point this was used for testing (though
test.osgeo.org), sort of like a staging server. But the records point to
IP addresses of non-existent servers now.
I propose to forward osgeo.net also to osgeo.org (I will await
feedback first though)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/162#comment:8>
Keywords: |
Comment (by strk):
I think it makes sense for osgeo.net to forward to www.osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/162#comment:9>
Keywords: |
I will have to delete all of the old A Record and other records, to enable
that. (there is even an MX record to 140.211.15.3 for mail.osgeo.net )
I still believe none of this is used anymore.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/162#comment:10>
