#1632: Virtualhost mixup: https://mapserver.org/ points to a GRASS site
Reporter: dmorissette | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Hi SAC, there seems to be a virtualhost mixup on the server hosting
MapServer.org. There is no HTTPS site for MapServer, but
https://mapserver.org/ points to a GRASS site. The same issue may be
present for other sites on the same server.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jef):
Was this already fixed? Works fine from here at least.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:1>
Keywords: |
Comment (by dmorissette):
Still an issue for me, and I'm not alone since this was reported by others
at the Paris sprint last week.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:2>
Keywords: |
Comment (by wildintellect):
I can confirm, http is fine https if you except the invalid certificate
that doesn't match goes to GRASS. Perhaps a temporary redirect for https
connections for now until we work out a valid certificate.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:3>
Keywords: |
I'm going to suggest we try this route for getting a free https
certificate https://letsencrypt.org/getting-started/
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:4>
Keywords: |
FYI we've started using letsencrypt here at Mapgears a few weeks ago and
it works great. It's straightforward and provides a certificate that's
trusted by the browsers.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:5>
Keywords: |
And actually, in the mapserver.org case, and possibly others, we do not
need the https for now, so it may be better to have a permanent redirect
to the http site to avoid duplicating the website contents and search
engine references under two sets of URLs.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:6>
Keywords: |
Comment (by jef):
Replying to [comment:2 dmorissette]:
others at the Paris sprint last week.
Sorry, I missed the s - so it's not working for me either. Sorry for the
noise.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:7>
Keywords: ssl |
Changes (by TemptorSent):
* keywords: => ssl
Comment:
This issue appears to be due to an improper SSL certificate, here is the
error text from firefox:
mapserver.org uses an invalid security certificate.
The certificate is only valid for drone.osgeo.org
Error code: SSL_ERROR_BAD_CERT_DOMAIN
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1632#comment:8>
