#1635: uk.osgeo.org
Reporter: jocook | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords:
Hello Sac,
I understand you are the people to speak to about getting uk.osgeo.org
created? Do you need anything from me to make this happen?
I've assigned it a major priority as we need it in place before we can
start advertising a conference that we're running in June.
Thanks
Jo
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1635>
OSGeo <http://www.osgeo.org/>
#1635: uk.osgeo.org
Component: Systems Admin | Resolution:
Keywords: |
Changes (by warmerdam):
* cc: warmerdam (added)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1635#comment:1>
#1635: uk.osgeo.org
Keywords: |
Comment (by jocook):
The Github URL this should point at is: http://osgeouk.github.io/
Thanks
Jo
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1635#comment:2>
#1635: uk.osgeo.org
Keywords: |
Comment (by wildintellect):
CNAME record added uk.osgeo.org -> osgeouk.github.io
As per https://help.github.com/articles/setting-up-a-custom-subdomain/
If that doesn't work, then I do know the A Record info for using Github
and can change it.
Please continue with the github side of the configuration and report back.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1635#comment:3>
#1635: uk.osgeo.org
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jocook):
* status: new => closed
* resolution: => fixed
Comment:
Done, works fine- thanks for your help! This ticket can be closed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1635#comment:4>
