#165: Wiki LDAP integration
Reporter: crschmidt | Owner: astrodog
Type: task | Status: assigned
Priority: normal | Milestone:
Component: Wiki | Resolution:
Keywords: ldap, wiki |
Comment (by strk):
The work is ready for test. Please go to https://dev.wiki.osgeo.org/w/ and
try logging in. Both LDAP and WIKI credentials should be accepted, unless
you have the same username on WIKI and LDAP, in which case only WIKI
credentials will be accepted for first login (you'll be able to then login
via LDAP after the merge operation). How's your experience ? Smooth enough
? Anything you'd change ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/165#comment:33>
OSGeo <https://osgeo.org/>
