#165: Wiki LDAP integration
Reporter: crschmidt | Owner: astrodog
Type: task | Status: assigned
Priority: normal | Milestone:
Component: Wiki | Resolution:
Keywords: ldap, wiki |
Comment (by strk):
When LDAP credentials don't work it is beacuse
your WIKI username is the same as the LDAP username.
This is a known issue described here:
https://git.osgeo.org/gitea/hexmode/WikiToLDAP/issues/3
I'm afraid the ball was dropped on this, and the only
improvement we're left with would be changing the error
message to suggest logging-in via the WIKI credentials.
I don't like this either, but the external consultant
(Mark aka hexmode) says it's too much work to allow
direct LDAP access in this case.
The good new is that you should still be able to access
via the WIKI credentials and you should be guided into
the migration process, after which you should be able
to login via LDAP (and no more via WIKI).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/165#comment:37>
OSGeo <https://osgeo.org/>
