#165: Wiki LDAP integration
Reporter: crschmidt | Owner: astrodog
Type: task | Status: assigned
Priority: normal | Milestone:
Component: Wiki | Resolution:
Keywords: ldap, wiki |
Comment (by strk):
I think he refers to this:
> the username was filled in 'Wiki-', which didn't work.
He means the browser input field is pre-filled with 'Wiki-$Username' on
next login.
I've had the same experience, and is indeed annoying.
The "didn't work" refers to using the 'Wiki-' prefixed username with which
the form is pre-filled.
I've no idea where that pre-fill comes from (a cookie?) or if the
extension can do anything about it.
Regarding the second prompt I also think I saw it once, but then
disappeared on next login, so not sure when the merge prompt should or
should stop popping up (still a cookie?).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/165#comment:49>
OSGeo <https://osgeo.org/>
