#165: Wiki LDAP integration
Reporter: crschmidt | Owner: astrodog
Type: task | Status: assigned
Priority: normal | Milestone:
Component: Wiki | Resolution:
Keywords: ldap, wiki |
Comment (by hexmode):
Replying to [comment:49 strk]:
> He means the browser input field is pre-filled with 'Wiki-$Username' on
next login.
> I've had the same experience, and is indeed annoying.
Agreed. And that login won't work after the merge because, after the
merge, that account doesn't exist.
I'm not sure what to do about it -- maybe we could destroy that cookie
after a merge? Or, better, replace it with a the name of the account that
it is merged to.
> Regarding the second prompt I also think I saw it once, but then
disappeared on next login, so not sure when the merge prompt should or
should stop popping up (still a cookie?).
I don't think I've seen that, but maybe I wasn't paying attention.
It would be good if wildintellect could confirm or clarify some more her.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/165#comment:50>
OSGeo <https://osgeo.org/>
