#165: Wiki LDAP integration
Reporter: crschmidt | Owner: robe
Type: task | Status: closed
Priority: major | Milestone: Sysadmin Contract 2021-I
Component: Wiki | Resolution: fixed
Keywords: ldap, wiki |
Comment (by robe):
Neteler can you see if you have access to your pages again? Hopefully I
didn't cause more damage than good.
I couldn't merge the accounts neteler / Neteler because the routine sees
them as the same name.
However I was able to use the Rename User feature to rename your ghost
account from neteler to Wiki-Neteler and then merge Wiki-Neteler into
Neteler (and deleted the Wiki one). Hopefully that did the trick. If so
I can do that with others that have ghost accounts.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/165#comment:81>
OSGeo <https://osgeo.org/>
