#1650: gogs sandbox
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: git, hosting
gogs is a Go Git Service similar to github/gitlab but with fully
internationalized interface and distributed under the MIT license:
https://gogs.io/
It does have a LDAP connector so could use OSGeo accounts out of the box
This ticket is to deploy a test instance.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650>
OSGeo <http://www.osgeo.org/>
#1650: gogs sandbox
Component: Systems Admin | Resolution:
Keywords: git, hosting |
Changes (by strk):
* cc: wildintellect, jef, martinspot (added)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650#comment:1>
#1650: gogs sandbox
Comment (by strk):
FYI: I've setup a sandbox on my own tv ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Unfortunately at the moment the service is unable to receive big
repositories.
I could only push the code for postgis-0.9 and even then it broke the
server.
But the LDAP authentication works nicely.
If you want to test (but please don't hammer and don't count on it to be
on) it is here:
http://tuscia.pallamondo.net
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650#comment:2>
#1650: gogs sandbox
Type: task | Status: closed
Component: Systems Admin | Resolution: wontfix
Changes (by strk):
* status: new => closed
* resolution: => wontfix
Comment:
Closing as wontfix
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650#comment:3>
#1650: gogs sandbox
Type: task | Status: reopened
Changes (by strk):
* status: closed => reopened
* resolution: wontfix =>
Comment:
Actually, I've finally moved the sandbox to osgeo, at the moment:
https://git.osgeo.org/_gogs_/ (to be moved to final url after some further
tests).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650#comment:4>
#1650: gogs sandbox
Comment (by strk):
I've wrote some info about Gogs, and about Git Services in general (follow
the links) from https://wiki.osgeo.org/wiki/SAC:Gogs
Further tasks for this install could be handled directly via Gogs:
https://git.osgeo.org/_gogs_/sac/gogs-config/issues (private)
https://git.osgeo.org/_gogs_/sac/gogs-service/issues (public)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650#comment:5>
#1650: gogs sandbox
Component: Systems Admin | Resolution: fixed
Changes (by strk):
* status: reopened => closed
* resolution: => fixed
Comment:
This is ready
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1650#comment:6>
