#1657: Add backup for tracsvn:/home/git/gogs/data
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
The directory contains attachments to the Gogs ticket,
see https://wiki.osgeo.org/wiki/SAC:Gogs#Files_location_and_configuration
(which needs to be updated once backups are in place).
It would also be useful to mention what's backed up in
https://wiki.osgeo.org/wiki/SAC:Backups
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1657>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
Martin do you receive a notification for this ticket ?
Did you add this backup ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1657#comment:1>
Keywords: |
Comment (by strk):
This is still needed.
I'm unable to tell if backups are in place or not.
Can anyone help ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1657#comment:2>
Keywords: |
Comment (by strk):
I think I figured out how to do this
(https://trac.osgeo.org/osgeo/ticket/1845#comment:2), only have a decision
to make about whether to add more directories to the existing
{{{"TracFiles" FileSet}}} or create a new Job for the purpose (ie: a
{{{BackupGogs}}} job). I tend to prefer the former, interpreting "Trac" as
"The TracSVN machine" in a general sense (the currently backed up files
already also contain a full PostgreSQL cluster dump, which is not just
used for Trac).
Opinions on the matter, Martin ?
BTW, those bacula configs, I'd also put them under git, if nobody objects
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1657#comment:3>
Reporter: strk | Owner: strk
Type: task | Status: assigned
Keywords: gogs, backup, tracsvn |
Changes (by strk):
* owner: sac@… => strk
* status: new => assigned
* keywords: => gogs, backup, tracsvn
Comment:
The database also needs to be backed up via Bacula. I'll take care of this
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1657#comment:4>
