#1666: git does not trust new SSL certs
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: ssl, git
Attempts to git-push via https://git.osgeo.org/ result in :
fatal: unable to access
'https://git.osgeo.org/gogs/rttopo/librttopo.git/':
server certificate verification failed.
CAfile: /etc/ssl/certs/ca-certificates.crt
CRLfile: none
This started since the new SSL certificates were deployed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: ssl, git |
Comment (by strk):
According to http://stackoverflow.com/a/16577227 there's a possibility
that the intermediate cert file might benefit from a reordering, to work
around a GnuTLS bug.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:1>
Comment (by strk):
The error occurs to me by just running:
git clone https://git.osgeo.org/gogs/rttopo/librttopo.git
But only with git versions 1.7.10.4 and 1.9.1,
whereas git version 2.1.4 did not raise the error.
Maybe newer versions are not using GnuTLS (or are using a newer version of
it)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:2>
Comment (by strk):
I confirm reordering the contents of /etc/ssl/osgeo/ca-bundle-client.crt
fixed the issue.
Now I guess all other machines should be updated.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:3>
Comment (by martin):
Indeed, the CA certificate chain ordering as delivered by the CA is
'unfortunate' (uncommon),
Martin.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:4>
Comment (by strk):
Can anyone take care of copying the reordered chain from
git.osgeo.org to other machines ? I don't have sudo on the
required ones
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:5>
Comment (by strk):
Alex: was the copy over taken care of ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:6>
Comment (by wildintellect):
I didn't do it, seemed a minor issue outside of the git service... also
didn't want to rush in the event we decided to change certs again...
Someone else is welcome to do this fix too.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:7>
Comment (by strk):
It looks like it was decided not to change certs again, so for the next 3
years we keep these. As it's not been easy to spot, it'd be nice to not
hit this bug again in the future, if we decide to open more git services
via https on other machines...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:8>
Comment (by strk):
Martin, did you spread the change onto other machines ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:9>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
closing for lack of feedback, and assuming fixed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1666#comment:10>
