#1693: Slow DNS lookups on tracsvn
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: tracsvn, dns
I've just updated the Gogs implementation to cache DNS lookups because
otherwise it would take up to 14 seconds to render the user-explore page,
due to having to lookup the domain of each user's email in the page (~20
per page).
Now, with the cached lookups the time to render the page goes down from 14
second to 5 _milli_ seconds.
This tells me there's an issue with the DNS resolution.
I don't know which other services do use DNS lookups, but if any
production service does it too (beside Gogs which is only experimental)
we'd better install a local caching server, like dnsmasq (or, as I've been
suggested, "unbound").
Ok, after getting errors twice while responding to the ticket, I chose
to respond here:
Reporter: strk | Owner: sac@???
Hi Sandro, did you already switch Gogs over to using libc-based name resolution, as suggested ?
BTW, Trac error upon submission is:
Trac detected an internal error:
IndexError: list index out of range
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
to respond here:
I tried that locally and did not have a big speedup.
It was something like from 400ms to 330ms (locally).
Component: DNS | Resolution:
Keywords: tracsvn, dns |
Comment (by TemptorSent):
To explain further --
A recursive caching name server is used to look up and locally cache DNS
information from the appropriate authoritative name server, which it
discovers more or less in the following manner:
- starting at the root name server, it sends a query for the target
record; the root nameserver replies based on the TLD (top level domain -
osgeo.org, for example) with the address of the name servers for that
domain
- it then queries each successive name server recursively until it find an
authoritative record for the target
- each record has an associated TTL or "Time To Live", which determines
how long it is allowed to be cached for
DNSSEC uses cryptographic techniques to ensure that only records actually
originating from an authorized authoritative nameserver are accepted --
without this, a technique called DNS cache poisoning can be used to insert
records linking valid names to malicious addresses. Ensuring that only
DNSSEC authenticated records are cached when available will prevent a
large class of DNS related exploits.
Comment (by wildintellect):
I'm in favor of trying unbound, I have seen it in use around my work. Easy
to remove if it doesn't work. Question is, can we get it from repos on
such an old box?
Comment (by strk):
It would be also helpful to understand which services are doing
dns lookups, in case those lookups can be disabled. For example
I know for sure that Gitea is doing DNS lookups for finding
user avatars, and I also know Gitea must be compiled in a certain
way for it to be using the system resolver
Pretty much every service that logs incoming connections will be hitting
DNS (unless you explicitly turn it of, leaving just IPs), as does the mail
server (mandatory), and any thing else that wants to know the name, ip
address, mail server, dkim keys, or anything else that DNS provides.
Disabling nslookups in very specific cases where many cache-misses occur
on a regular basis, but otherwise it just makes sense to use a local fast
cache. We don't necessarily need to use the system resolver from gitea,
just point it at a the ip of the local caching server to use for lookups.
Comment (by strk):
Now available as packages in current TracSVN machine:
unbound 1.4.22-1~bpo70+1 (Installed-Size: 1585)
dnsmasq 2.62-3+deb7u4 (Installed-Size: 120)
I'd go the smaller route unless Unbound does anything that dnsmasq is not
doing..
Comment (by martin):
According to my experience, setting up dnsmasq as DNS cache on nowadays
Debian systems requires nothing else but installing the package.
Comment (by strk):
I've installed dnsmasq but /etc/resolv.conf is not automatically
updated to point to localhost, which makes me think it is NOT
enough to install the package.
I've manually added 127.0.0.1 as first entry i /etc/resolv.conf
Not sure how to test/compare performances now though
(nor how to convince Gitea to use 127.0.0.1 to lookup
names)
Ah ok, thanks for responding, maybe I'm using more recent versions of the
respective package.
The installer of the dnsmasq package I know puts the local host as the one
and only nameserver in /etc/resolv.conf and writes the forwarder into a
file somewhere in /var/run/dnsmasq/ or the like. If the dnsmasq process
proves to be robust, let's try that.
Comment (by strk):
I did not follow the debian guide completely, so for example
I don't know if dnsmasq is serving every host rather than just
localhost, can you check that part Martin ?
Is everybody using the system resolver or do some local services rely on
custom DNS configuration ?
Comment (by strk):
I'm not sure what Gitea (focus of this ticket) is using,
don't know how to tell. No idea about any other service.
I'd recommend to make the DNS cache listen on localhost only and configure
resolv.conf to connect localhost first.\\
If we're unsure, which services rely on connecting the cache, we might
simply enable the configuration that way and see if it breaks anything. Ok
Comment (by strk):
Just make sure to create a dnsmasq configuration file (and please put
under revision control) because the trick of having non-localhost
addresses in /etc/resolv.conf is supported by dnsmasq as a poor man's
configuration of it (dnsmasq will use the non-localhost addresses as
upstreams)
