#1731: pywps: Execute request fails ('NoneType' object has no attribute 'lower')
Reporter: sebastic | Owner: live-demo@…
Type: defect | Status: new
Priority: normal | Milestone: OSGeoLive10.0
Component: LiveDVD | Keywords:
The hello-world process in pywps fails Execute requests reporting:
The Apache error logs contains the stacktrace:
PyWPS [2016-06-10 17:58:40,353] INFO: Reading processes from directory
[/usr/local/share/pywps/processes]
PyWPS [2016-06-10 17:58:40,354] INFO: Following processes are imported:
['hello-world']
PyWPS [2016-06-10 17:58:40,357] INFO: Status [processpaused]: Getting
input name of process hello-world
File "/usr/lib/python2.7/dist-packages/pywps/Wps/Execute/__init__.py",
line 386, in __init__
self.consolidateInputs()
line 537, in consolidateInputs
resp = input.setValue(inp)
File "/usr/lib/python2.7/dist-packages/pywps/Process/InAndOutputs.py",
line 404, in setValue
self.storeData(input["value"])
line 457, in storeData
if (self.format["mimetype"].lower().split("/")[0] != "text" and
self.format["mimetype"].lower() != "application/xml"):
AttributeError: 'NoneType' object has no attribute 'lower'
PyWPS [2016-06-10 17:58:40,359] INFO: Status [processfailed]: 'NoneType'
To reproduce:
$ wget -q
"http://localhost/pywps/wps.py?SERVICE=WPS&Version=1.0.0&REQUEST=Execute&Identifier
=hello-world&DataInputs=name=foo" -O -
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1731>
OSGeo <http://www.osgeo.org/>
