#1768: Add information about ASCII only character requirement to
https://www.osgeo.org/cgi-bin/auth/ldap_edit_user.py
Reporter: ehjuerrens | Owner: sac@…
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
The form available via
has certain requirements on the input that are not clearly stated on the
page itself.
Please add something like "Please use only ASCII characters here!" to the
fileds "Full name" and "Surname".
The problem is that if non ASCII characters are used, the following error
message is displayed and the edit operation fails:
File "/usr/lib/cgi-bin/auth/ldap_edit_user.py", line 207, in
ldap_apply_user_info( userid, cn, sn, mail, password )
File "/usr/lib/cgi-bin/auth/ldap_edit_user.py", line 52, in
l.modify_s( target, ml )
File "/usr/lib/python2.6/dist-packages/ldap/ldapobject.py", line 322,
in modify_s
return self.result(msgid,all=1,timeout=self.timeout)
File "/usr/lib/python2.6/dist-packages/ldap/ldapobject.py", line 422,
in result
res_type,res_data,res_msgid = self.result2(msgid,all,timeout)
File "/usr/lib/python2.6/dist-packages/ldap/ldapobject.py", line 426,
in result2
res_type, res_data, res_msgid, srv_ctrls =
self.result3(msgid,all,timeout)
File "/usr/lib/python2.6/dist-packages/ldap/ldapobject.py", line 432,
in result3
ldap_result = self._ldap_call(self._l.result3,msgid,all,timeout)
File "/usr/lib/python2.6/dist-packages/ldap/ldapobject.py", line 96,
in _ldap_call
result = func(*args,**kwargs)
INVALID_SYNTAX: {'info': 'cn: value #0 invalid per syntax', 'desc':
'Invalid syntax'}
LDAP update has failed!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1768>
OSGeo <http://www.osgeo.org/>
