#1784: can not ssh to adhoc.osgeo.osuosl.org
Reporter: jachym | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
my login name should be 'jachym' the password I expect to be the same as
I'm using currently e.g. for trac, I'm listed at https://www.osgeo.org
/cgi-bin/auth/ldap_shell.py
still, I can not log in (using ssh) to adhoc.osgeo.osuosl.org: my password
does not work. Any hint?
Thank you
Jachym
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
Your LDAP record is missing
objectClass: posixAccount
I don't know how to add/remove it, the wiki page doesn't tell.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:1>
Keywords: |
Comment (by strk):
Ok this could be the fault of a recent change to the ldap_shell.py script.
Were you given shell access recently ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Confirmed, the script is currently unable to give users shell access.
Your account was fixed to get the appropriate class now, but the script is
still broken.
Will file a separate issue for that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:3>
Keywords: ldap |
Changes (by strk):
* keywords: => ldap
Comment:
For the record: the script was fixed (#1785)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:4>
Type: task | Status: reopened
Keywords: ldap |
Changes (by jachym):
* status: closed => reopened
* resolution: fixed =>
Comment:
I can confirm: yes, recently (yesterday) by tkralidis
Thank you for your help, still no luck:
jachym@krovak:~$ ssh jachym@adhoc.osgeo.osuosl.org
ssh_exchange_identification: read: Connection reset by peer
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:5>
Keywords: ldap |
Comment (by strk):
I'm afraid I don't know how to help with that.
IIRC it also happened to me and was fixed by Wildintellect.
Alex: ideas ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:6>
Keywords: ldap |
Comment (by strk):
Oh, maybe your IP is being banned for too many failed logins:
sshd[23260]: refused connect from XXX.168.191.132
You should be unbanned now, can you try again ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:7>
Keywords: ldap |
Comment (by jachym):
yes, that's my IP
still no luck
jachym@krovak:~$ ssh jachym@demo.pywps.org
maybe restarting some service? just asking - you know your job better than
I do mine.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:8>
Keywords: ldap |
Comment (by strk):
You were also cought by denyhosts, now cleaned manually.
Can you test again ? (with care, don't try more than once ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:9>
Keywords: ldap |
Comment (by strk):
Actually, denyhosts re-bans your IP after I clean it.
This is due to the configuration which checks the logs for
failed logins attempts, and only purges entries after 1 week.
It seems too much for me, I would lower it, but maybe
in your case you could be whitelisted ? Is your IP static and stable ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:10>
Keywords: ldap |
Comment (by strk):
Purge time is being discussed in #1787
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:11>
Keywords: ldap |
No, it's not. Will it be whitelisted again during next week? One week from
now, right?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:12>
Keywords: ldap |
Comment (by strk):
One week since last failed login attempt, I think.
If you are in rush I could temporarely whitelist you,
coordinating on IRC
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:13>
Keywords: ldap |
Comment (by strk):
Or, you could try logging in from a different IP
(maybe stepping by a different OSGeo machine, as you should have
access to all of them now)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:14>
Keywords: ldap |
Comment (by strk):
For the record, I temporarely added Jachim IP to hosts.allow and removed
it after he did log in.
Teoretically, he should be able to login again, from that IP, within one
week (until the purge time is changed, as requested in #1787)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:15>
Keywords: ldap |
Changes (by strk):
* status: reopened => closed
Comment:
Assuming fixed. Please reopen if there's anything more to do.
PS: AdHoc services should be moved elsewhere so please make sure to update
the associated wiki page if needed (with contacts and state):
https://wiki.osgeo.org/wiki/AdhocVM
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1784#comment:16>
