#1795: 2017.foss4g.org is down
Reporter: gsteinmon | Owner: sac@…
Type: defect | Status: new
Priority: blocker | Milestone:
Component: Systems Admin | Keywords: foss4g,cname
Hello,
I am not sure what happened, but the site is down and I think it's a CNAME
issue.
Can someone please have a look at this ASAP
https://help.github.com/articles/troubleshooting-custom-domains/
Thank you for your help,
-Guido
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1795>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: foss4g,cname |
Comment (by gsteinmon):
Also found this message in my repo settings:
Your site's DNS settings are using a custom subdomain, 2017.foss4g.org,
that's set up as an A record. We recommend you change this to a CNAME
record pointing at [YOUR USERNAME].github.io. For more information, see
https://help.github.com/articles/setting-up-a-custom-domain-with-github-
pages/.
the username in this case is "avidgeo"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1795#comment:1>
I notice in this ticket,
https://trac.osgeo.org/osgeo/ticket/1628#comment:8 it says that it is
pointing at 199.27.79.133 for avidgeo.github.io
When I go to http://avidgeo.github.io/ it is a link to the meetup page.
The IP of http://avidgeo.github.io/ appears to currently be 151.101.52.133
I can't help on this but these are some observations.
Eli
pages/.
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
Yeah,
I was also looking into it and it seems that the A record was a patch we agreed on, but the CNAME record is what they really want.
-guido
I can’t help on this but these are some observations.
Eli
Your site’s DNS settings are using a custom subdomain, 2017.foss4g.org,
that’s set up as an A record. We recommend you change this to a CNAME
pages/.
the username in this case is “avidgeo”
Sac mailing list
Sac@lists.osgeo.org
Sac mailing list
Sac@lists.osgeo.org
Comment (by martin):
DNS updated, let's see if this was the proper fix.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1795#comment:2>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by gsteinmon):
* status: new => closed
* resolution: => fixed
Comment:
Thanks, this seems to have fixed it. ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1795#comment:3>
