#1800: Add IRC gateway solution to OSGeo MatterMost installation
Reporter: msmitherdc | Owner: sac@…
Priority: normal | Milestone:
Component: Systems Admin | Keywords: MatterMost, IRC, infrastructure
The board is interested it testing out higher end clients that provide
more than irc ( slack,Gitter, etc). The solution being tested is
MatterMost (https://MatterMost.osgeo.kbt.io). Now we need to add an IRC
connection to support those users that wish to remain on IRC and / or
don't want to use MatterMost. One discussed solution is
https://github.com/42wim/matterircd. While this looks like a decent
solution, not much investigation has gone into this so whatever works best
from a SAC/infrastructure perspective is fine.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1800>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: MatterMost, IRC, infrastructure |
Comment (by msmitherdc):
This should also be moved to OSGeo domain and hardware as appropriate
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1800#comment:1>
Comment (by strk):
Note that Mattermost relies on GitLab for using the OSGeo credentials, so
if Mattermost goes prime-time, GitLab should follow it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1800#comment:2>
