#1827: Update mantra request instructions
Reporter: mloskot | Owner: sac@…
Priority: normal | Milestone:
Component: Systems Admin | Keywords: mantra
On the new user page: https://www.osgeo.org/cgi-bin/ldap_create_user.py
we explain the mantra can be obtained from the admins.
Due to numerous requests stating "I need a mantra" which are difficult to
verify, I propose to update the `ldap_create_user.py` page with this
simple instruction:
In order to verify your request, we will need to know a couple of details:
* Why you need to create a new OSGeo User?
* What are your affiliations? For example, university, company, pubic
profile on any of social sites like SourceForge, Twitter, GitHub,
BitBucket, or your posts archived in any of the OSGeo mailing lsits
(https://lists.osgeo.org), etc.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: mantra |
Comment (by strk):
You can propose modifications to that file via a pull request here:
https://git.osgeo.org/gogs/sac/web-cgi-bin/src/master/NEEDMANTRA.html
NOTE: you'll need to be logged or it'll be a 404
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:1>
Keywords: mantra |
Comment (by mloskot):
I'll keep it here.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:2>
Reporter: Mateusz Łoskot | Owner: sac@…
Keywords: mantra |
Comment (by rouault):
I suggest the following amendments to mloskot's proposal
so as to build "trust":
* Why do you need to create a new OSGeo User?
* If it is to report a bug, for example, mention which project is affected
and describe very briefly what the issue is (you'll be able to file a full
report in the ticket, once you are granted a OSGeo User)
* Or alternatively, please display one public affiliation. For example,
university, company, pubic profile on any of social sites like
SourceForge, Twitter, GitHub, BitBucket, or your posts archived in any of
the OSGeo mailing lsits (https://lists.osgeo.org), etc.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:3>
Keywords: mantra, ldap |
Changes (by strk):
* keywords: mantra => mantra, ldap
* cc: anitagraser@…, rduivenvoorde (added)
Comment:
Even: sounds good to me. Up for a patch ? Last time it was Anita sending a
patch.
You can also file a pull for this file https://git.osgeo.org/gogs/sac/web-
cgi-bin/src/master/NEEDMANTRA.html (you need to sign in to be able to see
it)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:4>
I'm logged in gogs and https://git.osgeo.org/gogs/sac/web-cgi-
bin/src/master/NEEDMANTRA.html is a 404 for me. I also feel like mloskot
that this situation is getting ridiculous.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:5>
Comment (by anitagraser):
Also 404s for me. Maybe missing rights? On https://git.osgeo.org/gogs/sac,
I can only see TracLDAPEmailResolverPlugin and gogs-service.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:6>
Comment (by strk):
Anita I needed you to login once to be able to grant you permission,
please try again now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:7>
Patch proposed in branch https://git.osgeo.org/gogs/rouault/web-cgi-
bin/src/improve_mantra_msg . Commit is https://git.osgeo.org/gogs/rouault
/web-cgi-bin/commit/97a9c61a902a07bc00140f888af5db2889df034f
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:8>
I see, works now. Thanks strk!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:9>
Type: enhancement | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Thanks Even, deployed: https://www.osgeo.org/cgi-bin/ldap_create_user.py
Anita, in case you want to suggest further changes, we learned that after
forking you'll also need to add someone in the Owners team as a
collaborator, to give access to your branch (but a simple patch attached
to trac is still accepted, and probably easier)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:10>
Thanks, I'm away from my home PC, so I'll just mention it here: There's a
typo in "mailing lsits". Otherwise, it looks fine to me.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:11>
Comment (by strk):
Typo fixed, thanks Anita
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1827#comment:12>
