#184: Please provide .pfx file for installation of SSL cert on MapGuideBeta
server...
Reporter: jbirch | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: |
In order to enable secure access to the MapGuide beta server's
administrator interface, it would be useful to have access to the OSGeo
wildcard SSL certificate on this computer.
Would it be possible for someone to please export a .pfx file from the
currently installed certificate on osgeo1 and give it to Jason?
The instructions for doing this can be found here
http://www.digicert.com/wildcard-export-import.htm
In the section called "Moving a Certificate from Apache to a Windows IIS
server". The name is somewhat misleading; it's copying not moving. The
first paragraph on that page says:
Wildcard SSL Certificates from DigiCertTM come with a Free Unlimited
Server License. This means that the Certificate can be installed on
unlimited additional servers after the Certificate is initially installed
on the first server.
I believe that the basic instructions on this page can also be used to
export the backup files from osgeo1 and import them into osgeo2.
Thanks!
Jason
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/184>
OSGeo <http://www.osgeo.org/>
