#1843: Add strk to sudoers on backup VM
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Needed to ensure backups are in place before starting the Trac upgrade
(#1816)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1843>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
I'm actually not sure what the policy is on that machine, because I see
the {{{sudo}}} group is empty. My public RSA key, in case that's the way
to get in:
ssh-rsa
AAAAB3NzaC1yc2EAAAADAQABAAABAQDXfHGzxlzPA9gjIpbHPjCQ2SHvWve+QgficecsCwjACiZvOLrh71XalGGGpbxANkzs7amZjbqpvVd6L3tQJAZK8pT5ljVSV1bx3pX4HxxcL9CpAMB+SfmdRjlTxJ5uvmDNZkHKZl17PglVRYaS+fBbGAJe4JCNhMBzN0szmI3YWHjKlaJtnlAK6NVPiTyrcxQoNkb+XsDq53TBUapfK78JrJssI/iyuqZZ0nkrCgQL92UACRl9a7Wlq0fswsASi8/X/5iKKQu3Qfxo7yKIi7EbxvXn6/rUnyoykM7SwKEXiK06ABZxw8/lN9qcZhhO8YEo+zairIyX4S5DfF+5kGn9
strk@cdb
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1843#comment:1>
Keywords: |
Comment (by martin):
Backup of Trac is three stages (defined in /etc/bacula/bacula-dir.conf on
backup):
1.) Create a full database dump on tracsvn using:
/usr/local/sbin/PGDump.sh
2.) Create a Trac-level dump /osgeo/trac_backup.zip on tracsvn using:
/osgeo/backup.sh
3.) Backup /osgeo/trac/ and /osgeo/trac_backup.zip to Bacula
I'vre now added "strk" to sudo on backup
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1843#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Thanks ! Will ask next questions on the list.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1843#comment:3>
