#1864: RuntimeError: maximum recursion depth exceeded while calling a Python
object
Reporter: mlennert | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Trying to display [https://trac.osgeo.org/grass/browser/grass-
addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py],
I get the following error:
Trac detected an internal error:
object
here was an internal error in Trac. It is recommended that you notify your
local Trac administrator with the information needed to reproduce the
issue.
To that end, you could [Create] a ticket.
[Create] is a button, but when I push it I get:
Request-URI Too Large
The requested URL's length exceeds the capacity limit for this server.
which is not surprising as the URL is:
https://trac.osgeo.org/grass/newticket?reporter=anonymous&summary=RuntimeError%3A+maximum+recursion+depth+exceeded+while+calling+a+Python+object&description=%3D%3D%3D%3D+How+to+Reproduce+%3D%3D%3D%3D
While+doing+a+GET+operation+on+\`%2Fbrowser
%2Fgrass-
addons%2Fgrass7%2Fraster%2Fr.northerness.easterness%2Fr.northerness.easterness.py`%2C+Trac+issued+an+internal+error.%0D%0A%0D%0A%27%27%28please+provide+additional+details+here%29%27%27%0D%0A%0D%0ARequest+parameters%3A%0D%0A{{{%0D%0A{%27path%27%3A+u%27
%2Fgrass-
addons%2Fgrass7%2Fraster%2Fr.northerness.easterness%2Fr.northerness.easterness.py%27}%0D%0A}}}%0D%0A%0D%0AUser+agent%3A+`Mozilla%2F5.0+%28X11%3B+Linux+x86_64%3B+rv%3A45.0%29+Gecko%2F20100101+Firefox%2F45.0`%0D%0A%0D%0A%3D%3D%3D%3D+System+Information+%3D%3D%3D%3D%0D%0A%27%27System+information+not+available%27%27%0D%0A%0D%0A%3D%3D%3D%3D+Enabled+Plugins+%3D%3D%3D%3D%0D%0A%27%27Plugin+information+not+available%27%27%0D%0A%0D%0A%3D%3D%3D%3D+Interface+Customization+%3D%3D%3D%3D%0D%0A%27%27Interface+customization+information+not+available%27%27%0D%0A%0D%0A%3D%3D%3D%3D+Python+Traceback+%3D%3D%3D%3D%0D%0A{{{%0D%0ATraceback+%28most+recent+call+last%29%3A%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
%2Fdist-packages%2FTrac-1.2.1dev-
py2.6.egg%2Ftrac%2Fweb%2Fmain.py%22%2C+line+617%2C+in+_dispatch_request%0D%0A++++dispatcher.dispatch%28req%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fweb%2Fmain.py%22%2C+line+253%2C+in+dispatch%0D%0A++++resp+%3D+chosen_handler.process_request%28req%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fversioncontrol%2Fweb_ui%2Fbrowser.py%22%2C+line+407%2C+in+process_request%0D%0A++++file_data+%3D+self._render_file%28req%2C+context%2C+repos%2C+node%2C+rev%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fversioncontrol%2Fweb_ui%2Fbrowser.py%22%2C+line+733%2C+in+_render_file%0D%0A++++force_source%3Dbool%28annotate%29%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fmimeview%2Fapi.py%22%2C+line+1035%2C+in+preview_data%0D%0A++++annotations%2C+force_source%3Dforce_source%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fmimeview%2Fapi.py%22%2C+line+781%2C+in+render%0D%0A++++qr+%3D+renderer.get_quality_ratio%28mimetype%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fmimeview%2Fpygments.py%22%2C+line+121%2C+in+get_quality_ratio%0D%0A++++return+self._types[mimetype][1]%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Futil%2F__init__.py%22%2C+line+1197%2C+in+__get__%0D%0A++++result+%3D+self.fn%28instance%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fmimeview%2Fpygments.py%22%2C+line+241%2C+in+_types%0D%0A++++js_entry+%3D+self._types.get%28%27text%2Fjavascript%27%29%0D%0A++File+%22%2Fusr%2Flocal%2Flib%2Fpython2.6
py2.6.egg%2Ftrac%2Fmimeview%2Fpygments.py%22%2C+line+234%2C+in+_types%0D%0A++++for+lexer_name%2C+aliases%2C+_%2C+mimetypes+in+get_all_lexers%28%29%3A%0D%0A++File+%22%2Fusr%2Flib%2Fpymodules%2Fpython2.6%2Fpygments%2Flexers%2F__init__.py%22%2C+line+45%2C+in+get_all_lexers%0D%0A++++for+lexer+in+find_plugin_lexers%28%29%3A%0D%0A++File+%22%2Fusr%2Flib%2Fpymodules%2Fpython2.6%2Fpygments%2Fplugin.py%22%2C+line+52%2C+in+find_plugin_lexers%0D%0A++++for+entrypoint+in+pkg_resources.iter_entry_points%28LEXER_ENTRY_POINT%29%3A%0D%0A++File+%22%2Fusr%2Flib%2Fpython2.6
%2Fdist-
packages%2Fpkg_resources.py%22%2C+line+453%2C+in+iter_entry_points%0D%0A++++for+dist+in+self%3A%0D%0ARuntimeError%3A+maximum+recursion+depth+exceeded+while+calling+a+Python+object%0D%0A}}}&create=Create#
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1864>
OSGeo <http://www.osgeo.org/>
