#1869: Switch trac to mod_wsgi
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: normal | Milestone:
Component: Trac | Resolution:
Keywords: |
Comment (by TemptorSent):
If the wsgi module matching the running version of apache is available,
then by all means install it and test it against one of the instances if
the trac configuration will allow that (being sure to make a backup before
attempting of course).
As for tracd in standalone mode - it wouldn't cut it on its own, but
behind a proxying load-balancer (Apache, nginx, etc.), it may be on par
with wsgi and would allow running instances as different users or even
split across multiple servers in the long run. See
https://trac.edgewall.org/wiki/TracNginxRecipe for an nginx example.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1869#comment:5>
OSGeo <http://www.osgeo.org/>
