#1872: GRASS trac do not show latest commits
Reporter: martinl | Owner: sac@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords: grass, trac
GRASS trac shows in timeline (1) last commit as 70514. The following
commits are ignored.
GRASS 7.3.svn (nc_spm_08_grass7):~/src/grass_trunk > svn up
Updating '.':
At revision 70525.
See eg. (2)
(1) https://trac.osgeo.org/grass/timeline
(2) https://trac.osgeo.org/grass/ticket/3280#comment:1
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: grass, trac |
Comment (by strk):
Found: probem is trac env path changed but SVN hooks script still
reference
the old path. So broken by #1684 (to be reopened until this is fixed)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872#comment:1>
Comment (by strk):
SVN hook should be fixed now.
I'm not sure if a full re-sync needs to be enforced or if things
will be good starting from next commit. Please report here what
happens on next commit. Thanks !
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872#comment:2>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 strk]:
Seems to be fixed. Thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872#comment:3>
Type: defect | Status: reopened
Changes (by rouault):
* status: closed => reopened
* resolution: fixed =>
Comment:
The same issue affects GDAL as well:
https://trac.osgeo.org/gdal/ticket/6808
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872#comment:4>
Comment (by strk):
The fix should be working for all the instances, did you try a new commit
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872#comment:5>
* status: reopened => closed
Comment:
Looks like it works again now. Thanks
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1872#comment:6>
