#1878: Unable to create new Wiki page
Reporter: Mateusz Łoskot | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: wiki
I'm logged in to GDAL Trac.
I'm trying to create new page by editing the URL to access non-existing
Wiki page, namely:
https://trac.osgeo.org/gdal/wiki/GeneratingVisualStudioProject
I expect to see a button to confirm I want to create/edit the new page.
Instead, I get this error:
Trac Error
Page GeneratingVisualStudioProject not found
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: wiki |
Comment (by strk):
Does it happen with all trac instances ?
I do see a create button [here](https://trac.osgeo.org/osgeo/wiki/Test),
for example, do you ?
Does the error page you see give you any information about your login
status ? (as I've seen reports about missing cookies).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:1>
Keywords: wiki |
Comment (by Mateusz Łoskot):
Yes, I see the button on at least two instances, OSGeo and GEOS
I'm member a Trac admin on both.
On GDAL Trac, I'm not member of admins.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:2>
Keywords: wiki |
Comment (by strk):
Is there any other trac instance where you can create wiki pages
while not being admin ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:3>
Keywords: wiki |
Yes, there is PostGIS
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:4>
Keywords: wiki |
Comment (by strk):
Sorry, looking at permissions for GDAL I indeed see
that wiki creation is not granted to authenticated users.
Here are the perms:
trac_gdal=# select * from permission where action like 'WIKI%';
username | action
anonymous | WIKI_VIEW
developers | WIKI_ADMIN
authenticated | WIKI_MODIFY
sgillies | WIKI_CREATE
(4 rows)
And you are not in the "developers" group Mateusz:
trac_gdal=# select * from permission where action = 'developers';
username | action
dron | developers
warmerdam | developers
dmorissette | developers
tamas | developers
rouault | developers
hobu | developers
schwehr | developers
jratike80 | developers
(8 rows)
Note that all developers also have TRAC_ADMIN, so ask any of them
about the policy.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:5>
Keywords: wiki |
Sandro, thanks for figuring out.
Even, could you add me to the 'developers' group in Trac, please?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:6>
Keywords: wiki |
Comment (by strk):
Since I was at it, I did it, can you check if it works ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:7>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: wiki |
Changes (by Mateusz Łoskot):
* status: new => closed
* resolution: => fixed
Comment:
It works. Thanks Sandro!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1878#comment:8>
