#1903: Add Trac XML-RPC Plugin
Reporter: Mateusz Łoskot | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: trac,geos,gitlab
May I request to install the XML-RPC Plugin for our Trac?
https://trac-hacks.org/wiki/XmlRpcPlugin
AFAIU, it will be accessible only to the authenticated users.
I need it to evaluate Trac to GitLab migration, with pilot project is to
migrate GEOS data to GitLab.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1903>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: trac,geos,gitlab |
Comment (by strk):
Please check if the XMLRPC plugin works fine with Trac 1.2
Also, I remember you mentioned a CSV export, is that something we can
do w/out this XMLRPC plugin ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1903#comment:1>
Comment (by Mateusz Łoskot):
Yes, it should work w/ Trac 1.2 (https://trac-hacks.org/changeset/16279)
Do you see a problem with installing the plug-in? A security issue?
If possible, I'd like to try the Trac API.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1903#comment:2>
Comment (by strk):
I don't see an issue with that.
Do you have privileges to do the install yourself system-wide ?
Chances are XML-RPC module would also make it easier to use command-line
tools (right now I'm using cartman which scrapes the web page...)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1903#comment:3>
No, I don't have any system-wide admin privileges and I'm not going to
request any such privileges. I prefer to reach out experienced OSGeo
sysadmins w/ my request.
Yes, Trac access via a Web API could be useful others too.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1903#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: wontfix
Changes (by Mateusz Łoskot):
* status: new => closed
* resolution: => wontfix
Comment:
Dropping the idea.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1903#comment:5>
