#1910: GeoTIFF Trac does not show latest SVN revision
Reporter: rouault | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
https://trac.osgeo.org/geotiff/browser/trunk is stuck at revision 2751
whereas I committed 2762 4 days ago.
I'm wondering what happened between 2751 and 2762... Those revisions seem
to exist nowhere.
And strangely https://trac.osgeo.org/geotiff/log?rev=2762 mentions a r2762
47 years ago...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by rouault):
My local svn log
r2762 | rouault | 2017-04-14 13:48:02 +0200 (ven. 14 avril 2017) | 1 ligne
replace CPL_DLL by GTIF_DLL
r2751 | rouault | 2017-01-10 13:53:58 +0100 (mar. 10 janv. 2017) | 1 ligne
Update to EPSG v9.0 (#83)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:1>
Keywords: |
Comment (by strk):
There is something wrong with trac configuration for geotiff.
The [repositories] section of trac.ini only mentions an SVN
repository path that does not exist.
Who's the manager of that instance ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:2>
Keywords: |
Comment (by strk):
geotiff, as well as csmap, proj4j and proj4js all list a subdirectory
of the "metacrs" svn repository as their repository base directory.
But the metacrs "post-commit" hook only reports the changes to
the "metacrs" trac instance, which would explain a lost sync.
Enabling per-request sync in the geotiff trac.ini doesn't seem to get
back in sync though, not sure if that's related to this weird layout
(subdirectory in SVN, which doesn't exist on the filesystem).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:3>
Keywords: |
Comment (by strk):
I shall note that latest SVN revision is known by the `metacrs` trac
instance, which is where all commits for the aforementioned projects get
notified:
https://trac.osgeo.org/metacrs/log/
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:4>
Keywords: |
Comment (by strk):
I've manually re-synced the repository, which fixed the current situation,
but I'm afraid the per-request sync is not working, which means things
will get out of sync again on next commit.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:5>
Keywords: |
Comment (by strk):
So after testing with Even we can confirm that the `.sync_per_request =
true` trac.ini setting does NOT work for subdirectory Subversion
repository. This should probably be filed upstpream to Trac trac.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:6>
Keywords: |
I've attempted to report to upstream Trac:
https://trac.edgewall.org/ticket/12778
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:7>
Reporter: rouault | Owner: strk
Type: task | Status: closed
Component: Trac | Resolution: fixed
Keywords: |
Changes (by strk):
* owner: sac@… => strk
* status: new => closed
* component: Systems Admin => Trac
* resolution: => fixed
Comment:
I finally sorted this out: the per-request sync was not working due to a
syntax error in trac.ini (using hash for inline comment is not
appropriate, you need semicolons). Now I've fixed the syntax and enabled
per-request sync for all affected projects (metacrs sub-projects). And I
filed #1911 to improve the performance by using proper explicit sync
again.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1910#comment:8>
