#1931: Add public SSH key for new community build server and build.geoserver.org
redirect
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: geotools, geoserver
The legacy Ares server is being replaced by a new/improved build server
known as Apollo. We're unable to deploy build artifacts to "geotools.org"
at this time. From what I can gather, the server there uses a public key
file /etc/ssh/ssh_host_rsa_key.
1) We need the Apollo public key added to this file to deliver the builds.
The key has been added to /home/geotools/.ssh/authorized_keys. It is also
below:
ssh-rsa
AAAAB3NzaC1yc2EAAAADAQABAAABAQDpAbNuNhile/uGIp/yzBJqVFl1Ce2kwLp1gun21j/x+mIj4W4QdpF5nmfkY2LJCa+Al/dtgmKtgnCzIouNiUw9OEZGmFRxx3M3Lv8XkyGaNlasgDlzP0sLryjSzv2dlcRsTLpk2JHEWQrz1eBjMv/J1Bt0EVZwJd3kfxJEPdroRCNG/V96O9ULEhXUHnJlr3XJLbfY+hDpbY1Ockq1V26xw8dP35rywAHLSnPRcgSm6cMadfevx+wlQLbHmScbV0GYNmzyfym3PWmJnOWaoI3e39y/aU8sJAzsuL3qq5hfBvEI3uAwPWse77SdIlpiXh6Ve6TJ3RTt8a5aXQj5luY7
root@apollo.boundlessgeo.com
2) Secondly we would ask build.geoserver.org to be redirected to this new
build sever.
See https://osgeo-org.atlassian.net/browse/GEOT-5745 for details
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1931>
OSGeo <http://www.osgeo.org/>
redirect
Component: Systems Admin | Resolution:
Keywords: geotools, geoserver |
Comment (by jive):
From Nick:
For build.geoserver.org would need an "A" record added for build dot
geoserver dot org to 34.204.115.146
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1931#comment:1>
redirect
Comment (by jive):
Checking geotools build
https://github.com/geotools/geotools/blob/master/pom.xml#L1897
We are deploying to:
<url>dav:http://download.osgeo.org/webdav/geotools/</url>
So I am not quite sure what to make of this request.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1931#comment:2>
redirect
Comment (by jive):
Figured it out geotools.org is required for deploying the docs.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1931#comment:3>
redirect
Comment (by wildintellect):
1. geoserver.org is not managed by OSGeo, the Whois is protected so
hopefully you know who actually maintains it's registration.
2. Authentication over webdav is not handled by ssh keys but OSGeo LDAP.
Did you want access to the folder on the server with ssh?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1931#comment:4>
redirect
Reporter: jive | Owner: warmerdam
Changes (by warmerdam):
* cc: warmerdam (added)
* owner: sac@… => warmerdam
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1931#comment:5>
