#1938: Upgrade distribution from Squeeze to Jessie to Stretch to Buster
Reporter: strk | Owner: robe
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution:
Keywords: distupgrade |
Comment (by robe):
The upgrade somehow broke the mail on trac. Trac was using local smtp
which I think is postfix. I can't figure out what is up since doing a
test mail worked.
For now I changed the /var/www/trac/env/osgeo/trac.ini
:/var/www/trac/env/postgis/conf/trac.ini to use mail.osgeo.org. Which is
fine.
But I would like to troubleshoot why it's not working since I may run into
the same issue upgrading osgeo6 (mail.osgeo.org)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1938#comment:23>
OSGeo <https://osgeo.org/>
