#1938: Upgrade distribution from Squeeze to Jessie to Stretch
Reporter: strk | Owner: robe
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution:
Keywords: distupgrade |
Comment (by robe):
I plan to upgrade tracsvn to stretch after I'm done with osgeo6. I
started the ball rolling by switching to the osuosl.org jessie distro (the
one tracsvn had was out of commission). That resulted in a number of
upgrades of core files.
The following NEW packages will be installed:
linux-image-3.16.0-11-amd64{a}
The following packages will be REMOVED:
libuuid-perl{u}
The following packages will be upgraded:
apache2-utils apt apt-transport-https apt-utils bash bind9-host busybox
bzip2 ca-certificates cpio cpp-4.9 cron curl dbus dnsmasq dnsmasq-base
dnsutils doxygen doxygen-latex e2fslibs e2fsprogs file g++-4.9 gcc-4.9
gcc-4.9-base git git-core git-daemon-run git-man git-svn
imagemagick-common krb5-locales ldap-utils libapache2-svn libapt-inst1.5
libapt-pkg4.12 libarchive-zip-perl libasan1 libatomic1 libbind9-90
libbsd0 libbz2-1.0 libcilkrts5 libcomerr2 libcurl3 libcurl3-gnutls
libdbus-1-3 libdns100 libelf1 libexpat1 libexpat1-dev libfreetype6
libfreetype6-dev libfuse2 libgcc-4.9-dev libgcc1 libgcrypt20
libgfortran3 libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libglib2.0-0
libglib2.0-data libgnutls-deb0-28 libgnutls-openssl27 libgomp1
libgsf-1-114 libgsf-1-common libgssapi-krb5-2 libharfbuzz0b libice6
libicu52
libidn11 libisc95 libisccc90 libisccfg90 libitm1 libjson-c2 libk5crypto3
libkrb5-3 libkrb5support0 liblcms2-2 libldap-2.4-2 liblsan0
liblwres90 libmagic1 libobjc-4.9-dev libobjc4 libpcap0.8 libpixman-1-0
libpolkit-gobject-1-0 libpython2.7 libpython2.7-dev
libpython2.7-minimal libpython2.7-stdlib libpython3.4-minimal
libpython3.4-stdlib libquadmath0 libsasl2-2 libsasl2-modules libsasl2
-modules-db
libsqlite3-0 libss2 libssh2-1 libssl-dev libssl-doc libssl1.0.0
libstdc++-4.9-dev libstdc++6 libsystemd0 libtasn1-6 libtsan0 libubsan0
libudev1 libx11-6 libx11-data libx11-xcb1 libxcursor1 libxdmcp6 libxml2
libxslt1.1 linux-base linux-image-amd64 linux-libc-dev mutt ntp
openssh-client openssh-server openssh-sftp-server openssl patch python-
apt python-apt-common python-lxml python-reportbug python-subversion
python-urllib3 python-urllib3-whl python2.7 python2.7-dev
python2.7-minimal python3-apt python3-magic python3.4 python3.4-minimal
reportbug
rsync rsyslog ssh sudo tar tzdata udev unzip vim vim-common vim-runtime
vim-tiny w3m wget zlib1g zlib1g-dev
The following partially installed packages will be configured:
linux-image-3.16.0-6-amd64
The following packages are RECOMMENDED but will NOT be installed:
dns-root-data libtxc-dxtn-s2tc0 python-ndg-httpsclient python-openssl
python-pyasn1 xdg-user-dirs
162 packages upgraded, 1 newly installed, 1 to remove and 93 not upgraded.
Need to get 164 MB of archives. After unpacking 175 MB will be used.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1938#comment:15>
OSGeo <https://osgeo.org/>
