#1981: E120171: Error running context: An error occurred during SSL communication
Reporter: martinl | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: svn, openssl
Dear SAC,
since today I am unable to update GRASS SVN repo:
Updating '.':
svn: E170013: Unable to connect to a repository at URL
'https://svn.osgeo.org/grass/grass/trunk’
svn: E120171: Error running context: An error occurred during SSL
communication
Could be related to recent changes in Debian regarding OpenSSL (1). Is
there anything related to OSGeo server or just my issue? Thanks for
clarification. Martin
(1) https://lists.debian.org/debian-devel-announce/2017/08/msg00004.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: svn, openssl |
Comment (by neteler):
Your assumption could be right:
https://www.ssllabs.com/ssltest/analyze.html?d=svn.osgeo.org&latest
--> " The server supports only older protocols, but not the current best
TLS 1.2. Grade capped to C.
* TLS 1.3 No
* TLS 1.2 No
* TLS 1.1 No
* TLS 1.0 Yes"
An upgrade of the server configuration would be a good idea.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:1>
Priority: critical | Milestone:
Changes (by martinl):
* priority: normal => critical
Comment:
Replying to [comment:1 neteler]:
So I am taking liberty to increase priority. For now I will try to
downgrade openssl package on my PC.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:2>
Comment (by strk):
It looks like it'd take manually compiling libssl and mod_ssl.
Or upgrade to a still supported Debian version (even backports repository
has been obsoleted)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:3>
Comment (by strk):
Or switch to https://mod.gnutls.org/ ...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:4>
Comment (by strk):
It looks like The version of gnutls on that server already supports TLS1.2
$ gnutls-cli -l | grep TLS1.2
Protocols: SSL3.0, TLS1.0, TLS1.1, TLS1.2
And the apache module is available, so could be a viable path to switch to
that.
Only it might taking tweaking some apache configurations (/etc/apache is
under a local git repository though, which should help)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:5>
Comment (by strk):
For the record: Ubuntu 17.04 does not ship mod_ssl anymore, but it does
ship mod_gnutls.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:6>
Comment (by mlennert):
Just a ping, confirming the same issue for me. And yes, this happens after
the Debian OpenSSL upgrade.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:7>
Comment (by jef):
quick workaround:
apt-get build-dep openssl
apt-get source openssl
cd openssl-1.1.0f
sed -i -e "s/disable-tls1 disable-tls1_1/# &/" debian/rules
DEB_BUILD_OPTIONS="nocheck parallel" dpkg-buildpackage -us -uc -b
sudo dpkg -i ../libssl1.1_1.1.0f-4_amd64.deb
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:8>
Comment (by strk):
For those like me who receive comments by mail: the suggested workaround
is for clients, not server (post-submit edit of trac comments are not
notified by mail, the info was added later)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:9>
Thanks for the workaround. Are there any plans of upgrading the server so
it supports 1.2+ ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:10>
Comment (by martinl):
Any chance to get svn server fixed to support 1.2+?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:11>
Comment (by strk):
I don't have time to work on it, but if anyone else does
I suggest to look at GNU-lts module (is avalable as packaged
for the version of OS on that system).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:12>
Comment (by rduivenvoorde):
During OSGeo-NL GRASS-intro, we were hit with this one too ![:frowning: :frowning:](/images/emoji/twitter/frowning.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:13>
Priority: blocker | Milestone:
Changes (by strk):
* priority: critical => blocker
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:14>
Comment (by goatbar):
Sigh. Hit the same on a debian testing based distro. ![:frowning: :frowning:](/images/emoji/twitter/frowning.png?v=12)
svn --version
svn, version 1.9.7 (r1800392)
compiled Aug 17 2017, 02:50:12 on x86_64-pc-linux-gnu
svn co https://svn.osgeo.org/gdal/trunk/gdal
'https://svn.osgeo.org/gdal/trunk/gdal’
communication
apt-cache show subversion
Depends: libsvn1 (= 1.9.7-2), libapr1 (>= 1.5.0), libaprutil1 (>=
1.3.2+dfsg), libc6 (>= 2.4), libldap-2.4-2 (>= 2.4.7), libsasl2-2
apt-cache show openssl | egrep 'Version'
Version: 1.1.0f-4
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:15>
Comment (by robe):
I have run into similar issues when using Caddy (for proxying). This just
highlights the fact we are desperately in need of upgrading the trac
server. The OS is just too old. It's running Debian 6 which at this point
is ancient.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:16>
Comment (by martin):
In order to resolve this issue I'm planning to upgrade the TracSVN VM this
Friday (2018-02-16) to a more recent version of Debian Linux. Outages will
occur at some point in the process, reboot will be synced with OSL staff.
Currently the following VM's still run an outdated distro, some of which
I'd prepare to upgrade as well:
secure / projects / web / download / tracsvn / wiki
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:17>
Comment (by strk):
Great news, thank you !
Please make sure to update the VM information on the wiki
at the end of the upgrade process.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:18>
Upgrade to Debian7 on TracSVN VM is almost complete, please report
features which might have gone lost.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1981#comment:19>
