#1996: Can't use OSGeo login to have access to trac.osgeo
Reporter: mlennert | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Hello,
We are using Moritz account because we aren't able to access to the
trac.osgeo although we are using our osgeo accounts (Maellevd and
Gildasjr).
The problem is that with our account we are only able to acces to the
OSGeo wiki and we don't know why. We are actually suspecting that the
problem may be related to our first capital letter.
Could someone help us fix it?
Thanks in advance,
Maëlle and Gildas
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1996>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by EliL):
Accounts for wiki.osgeo.org and for Trac are separate. You need an OSGeo
id (LDAP) to access Trac. http://www.osgeo.org/osgeo_userid should help
you out.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1996#comment:1>
Keywords: |
Comment (by Jeff McKenna):
As @Elil said, your wiki ID is not the same as the OSGeo Services ID. For
example, an account for "Maellevd" does not exist as an OSGeo Services ID.
You can create an OSGeo Services ID here (please do not enter any special
characters in any part of the form, as this will cause problems):
https://www.osgeo.org/cgi-bin/ldap_create_user.py Also, use the option
"Send mantra request via email" and I will watch for your email ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
You can also search for an existing OSGeo Services ID here:
http://www.osgeo.org/cgi-bin/ldap_web_search.py
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1996#comment:2>
Keywords: |
Comment (by strk):
For the record, this problem with the disjoint wiki/rest-of-the-world
accounts is tracked by #165
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1996#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: invalid
Keywords: |
Changes (by mlennert):
* status: new => closed
* resolution: => invalid
Comment:
Closing as invalid.
Thanks for the rapid responses !
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1996#comment:4>
