#2010: New Website allow LDAP integration
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Website rebranding 2017
Component: Systems Admin | Keywords:
As noted here:
https://lists.osgeo.org/pipermail/sac/2017-October/008719.html
We have new website development server setup.
Once Alex and Venkat work out contract with GetInteractive to move over
the site to our new server, we'll want to start implementing the LDAP
integration.
In order to do that in test environment, strk said it's doable but just
need to whitelist the IP.
The IP / name of new server is as follows:
IPv4 address..: 141.138.205.23
IPv6 address..: 2a02:348:84:cd17::1
Hostname......: osgeo.public.cloudvps.com
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
I found that IP already witelisted.
Took the chance to put /etc/init.d/ipfilter under
a local (/etc/init.d/.git) git repository
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:1>
Keywords: |
Comment (by martin):
Activated, meet ldaps://ldap.osgeo.org/, BaseDN is "dc=osgeo,dc=org",
people are in
"ou=People,dc=osgeo,dc=org", groups in "ou=Group,dc=osgeo,dc=org"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:2>
Keywords: |
Comment (by robe):
martin, strk thanks. Martin did you touch the new server at all wasn't
clear from your note above.
If not I'll try to do the next steps of configuring server for LDAP
authenticated ssh login.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:3>
#2010: New Website allow LDAP integration and enable ssh login with LDAP
Keywords: |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:4>
Keywords: |
Comment (by robe):
I'm not having much luck with getting SSH LDAP access working with the new
server.
Connecting to our ldap server works though since I can do:
ldapsearch -x uid=robe
and it gives me my account details.
The passwords for new server are in secure
access/osgeo.public.cloudvps.com
The steps I did so far detailed here:
https://wiki.osgeo.org/wiki/SAC:betawebsite
We have no instructions on how to configure a brand new server. All our
instructions assume you are starting with the OSGeo base VM.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:5>
Keywords: |
Comment (by robe):
Okay I got SSH working thru LDAP now by reverse engineering the osgeo6
stuff and updated the link above.
I did have to create local users though otherwise get invalid credentials.
Maybe that's always done.
Anyway I'll close this ticket out once someone checks my work.
I've added martin, wildintellect, strk to sudo group
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:6>
Keywords: |
Oh, I'm too late .... ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Did you actually use libpam/libnss-ldap*d* ? At least that would be the
recommended way in order to deal with GnuTLS setuid-habits. If you want me
to do so, I'd offer to check/revise the current setup tomorrow.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:7>
Keywords: |
Comment (by robe):
martin that would be great to look at it. I had installed libnss-ldap
after I installed the other ldap stuff and it threatened to remove a whole
bunch of things which I said no to. So not quite sure if it's in use or
not. Anyway if you want to check the setup tomorrow, that would be swell.
Anyway look at the link https://wiki.osgeo.org/wiki/SAC:betawebsite most
of the files after install of stuff were teh same as osgeo6 except for
ldap
/etc/nslcd.conf
and /etc/ldap/ldap.conf
which I emulated what I saw on osgeo6 server.
The one line that confused me on the ldap.conf of osgeo6 was the line
in /etc/ldap/ldap.conf
pam_groupdn cn=telascience,ou=Shell,dc=osgeo,dc=org
I wasn't sure why we have anything referencing telascience anymore.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:8>
Keywords: |
Comment (by strk):
I don't think we ever needed to create local users
for SSH login via LDAP to work.
Can you document the procudure required for enabling
the SSH login on the wiki ? Then we can tweak once the
need to create local user is sorted out.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:9>
Keywords: |
# Avoid error messages upon login
root@osgeo:~# aptitude install locales-all
# Have the preferred LDAP subsystem
root@osgeo:~# aptitude install libpam-ldapd libnss-ldapd
# Purge deprecated configs
root@osgeo:~# dpkg -l | grep \^rc | awk '{print $2}' | cut -f 1 -d \: |
xargs dpkg --purge
# Purge local user
root@osgeo:~# grep -v \^martin /etc/passwd > Hallo && cat Hallo >
/etc/passwd
root@osgeo:~# grep -v \^martin /etc/shadow > Hallo && cat Hallo >
/etc/shadow
root@osgeo:~# rm -vf Hallo
# Purge cache and reload LDAP stuff
root@osgeo:~# /etc/init.d/nscd stop; rm -vf /var/cache/nscd/*;
/etc/init.d/nscd start
root@osgeo:~# /etc/init.d/nslcd restart
# Voila
root@osgeo:~# getent passwd martin
martin:x:10026:100:Martin Spott:/home/martin:/bin/tcsh
# Have a homedir and proper login shell
root@osgeo:~# cp -a /etc/skel /home/martin
root@osgeo:~# chown -R martin:100 /home/martin
root@osgeo:~# aptitude install tcsh
# Reduce authentication error log
root@osgeo:~# aptitude install fail2ban
BTW, using "*-ldapd libraries and nslcd makes /etc/ldap/ldap.conf obsolete
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:10>
Keywords: |
Comment (by strk):
Thanks for the report !
(worth adding in a wiki page)
About this:
Isn't it possible to get a group for each user, as it is
common since a long time in standard debian systems ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:11>
Keywords: |
This is my watered-down reponse ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Of course it's technically possible, but what's the benefit to justify the
maintenance overhead ?
Just because some Linux distros do it doesn't imply that it makes sense
for serious environments.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:12>
Keywords: |
Comment (by strk):
The benefit is we can set umask to 0002 and thus use set-gid
directories more. Just a way to reduce access to just the
needed one, rather than giving sudo to everyone ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
That said, I'm probably too much of a control freak.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:13>
Keywords: |
To me it's not a matter of being a control freak or not, I *do* care about
the health of the systems I maintain!
If you can elaborate a use case in OSGeo land which can't be solved
without distinct groups for every single user, I'll (probably ;-)) give
up my resistance.
Instead, from my perspective the risk to OSGeo's server infrastructure
isn't a technical one. Better control over directory permissions *is*
technically possible in many cases, but in some people simply prefer
granting "sudo" permissions because it's less burdensome and you're not
going to solve that one by creating thousands of individual user groups.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:14>
Keywords: |
Comment (by strk):
I agree the problem is more with culture than technical limit.
The umask idea only serves the purpose of reducing the effort
required to properly set group permissions when creating files
in a "group" area. When such directories have the set-gid flag
set files you create in them are automatically assigned to the
directory group, and with proper umask are also writeable by
them. Example use ? ~/root/access/<subsystem> on `secure` host
could be only granted access to those who need to take
care of <subsystem>.
Anyway, forget about it, not worth the effort, probably
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:15>
Keywords: |
Comment (by robe):
martin can you update https://wiki.osgeo.org/wiki/SAC:betawebsite with the
changes you made to the server.
I used apt-get for example and your above usese aptitude. So not sure if
you switched to using aptitude or continued with apt-get.
Also regarding your irc. I didn't install rpc:bind or not intentionally
so if you see it guess you can remove it.
I'm going to move the rest of this LDAP discussion to another ticket.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:16>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I added martin's step to the above link so I'm closing this out.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2010#comment:17>
